All of a sudden my battery started draining out very quickly.
When I open my camera it shows camera do not exist what should I do with this problem.
I has just been 5 months I brought this phone that to my first owned salary and facing this problem really makes me cry .
Please try helping me out what I should do with this phone.
I even did a factory reset which solved many of the other problems but this two problems are not regret I solved please help me out.
I regret I brought this worst phone
Better get it to the sony service center near you. and get them fix the issue
Hi there,
Repair the phone using Sony Update Service, make sure the battery at least charged 70 % before you start.
Cheers.
Hi Shamili,
If u are not able to solve this problem even after factory reset. Better take it to the sony service center and get them fix it.
i did the update yu said but my phone already has the updated version it shows me dat :(:smileycry:
What will be the charge for getting my mobile's camera gt fixed
