Hi, I've previously had no problems with my DVD but now when it goes into standby or switched off the tv doesn't receive a through signal. I've switched off the power save options but it hasn't made any difference. Any ideas? Many thanks in advance.
are you sure the energy saving mode is set to off? Mode 2 is the one that switch off the passthorugh signal on the antenna. In any case the recorder has to be plugged to power in order to pass the signal.
You can also back track? When was the last time this worked? And any chages made so far?
