I have a RDR-HXD890 recorder which has ceased to format any type of dvd discs supposedly supported
on this recorder. keeps insisting unable to format either automatically or by disc set-up menu.
any ideas or help appreciated.
You can also check device manager and veryify if the correct driver is installed here.
