I have a problem with ht-ct390 the first one I had stopped working all the time after 3 weeks got a replacement and that’s fine apart from when I have a Samsung DVD player attached tried different hdmi cable and different port had Sony tv and Sony soundbar 4 months DVD player works fine with tv alone and with any other tv any ideas
Hi Dalton1234,
What seems to be the problem when you connect your Samsung DVD player? Also, could you tell us more about the connection you're having the issue with?
Vanilla_
Hi Dalton1234,
If the issue affects the soundbar even when it's connected to a different blu-ray player, you could try to reset it to see if this would make any difference. You can follow the steps on Page 26 of the User Manual here: http://clc.am/ZY0jBw
Regards,
Vanilla_
