Just need to know how to reset the above HDD as the picture freezes but the sound still plays.
can not download the pdf from the sony site, tried on a few computers but to no avail!
I am able to download the user manual without problems..:smileyconfused:
I've attached the RDR-DC205 Operating Instructions pdf below, hopefully you can download this file without problems..
1. be sure the recorder is switched on and no disk is on the tray
2. press the stop button on the recorder (not the remote) and the switch-off button together
I don't think it will solve your problem ...
Thanks for the replies!!
I was able to download the pdf no problem, no idea why i couold not from the site!
Thanks again
Excellent..:smileyhappy:
Ive tried to download the software update from the Sony site, but my (mac) computer doesnt recognise the programme and in consequence, i cant download it.
I've just tried with my own iMac/Safari browser and it downloads the file 1.11-p3-spi.pac without any problem and do not try in anyway to open it (why it should?). It's also rather old update as the machine itself is rather old.
