i had a power cut since then the signal input shows a x on all possible inputs projector turns on lights up all good is this a easy fix ? projector quiet old VPL-VW100 any help please
Hi there
Ive had a look at the manual:
So if everything is connected properly, i can only assume a hardware fault. Ive also looked at the service manual, but cannot find anything about this to be honest.
Best to contact an authorised Sony repair centre, i think.
Hi there
You can try a local repair firm, but if parts are needed, they may struggle to obtain them.
You could see if you have an authorised Sony one loca, to you:
http://services.sony.co.uk/support/en/repair/asc
