I am having the same connectivity issues. Everything is listed as working, yet I still get the "Checking Network Connection: Please Wait" then getting bounced back to the Netflix/Amazon Prime/Pandora/etc icon with nothing happening. I have tried factory reset, disconnecting the modem and the player then plugging them back in, changing the DNS Servers to 8.8.8.8 and 8.8.8.4, setting up a new network, and nothing works. Every other WiFi connected device in the house is working fine. I am using a FiOS router.
The previously provided link that explains how to fix this issue is no longer working. Could you please explain the process to fix this issue?
I have had the same issue since Thursday. Everything was fine the last time I used it then it said the same thing whenever I tried to watch Netflix, Hulu, or any other network. I kept doing the same thing, disconnecting then reconnecting, the Internet said there was connection but the networks still wouldn't respond. How can this be solved?
The only solution I've found is to throw this player in the trash and buy a better brand.
I have the same problem but when i try your link, I won’t get into the solution.
If you could send again this link will be great!
I having the same problem and I've tried clocking on the link,but nothing happens . Is there any chance it could be reposted ust in case it's been deactivated. Many thanks
The solution link is not available, are you able to please send steps or another link? What other manual settings? Many thanks
The solution is no longer available! Help! Can it be reposted?
Hey Ricardo16, could you add the model number and more details about the issue that you're experiencing?
Also, what solution isn't available? Could you clarify this part? This is a thread from 2016, so I'm not sure if you're having the same issue.
