I just bought a BDP-S3700 and had exactly the same problem. I could connect to my wifi but failed to connect to the internet. I called my ISP butthey said as everything else connected to my wifi, it must be an issue with the DVD player.
I found the answer in the Support community, the link is
You need to enter some settings manually to connect. The important one is tis
I have an iMac and it is in system preferences, network.
I'm no ID guru but I did it. I nearley tore all my hair out and was just about to give up and return the DVD player to the store.
Good luck.
Hi there
Unfortunately this is not the first time ive seen this issue on this forums - but I have also not received a concrete answer as of yet on the solution or at least a work-around.
Linking this post to your's
As for your immediate concern:
Give that a go and see if it works.
Hi Quinnicus
Thanks for your response. I have done the factory reset but unfortunately it made no difference.
For some reason, one day this week the player started working fine again, without me doing anything at all. But that only lasted for one evening and now it's back to not connecting again - like the other user said, the player says "physical connection OK, internet connection FAILED". It's the same when I connect via ethernet cable too.
I will check the firmware version later and update if needed.
For info, before posting on here I did accidentally post the problem on the Sony US community forum here and got the following response but I don't understand half of what it's telling me to do so haven't tried this:
1. Restart the router:
Turn off the wireless device.
Unplug both the router and modem.
Leave both the router and modem unplugged for 2 minutes.
Plug in the modem, and then plug in the router.
Allow 3-5 minutes for the modem and router to completely restart.
Turn on the wireless device.
2. Make sure the wireless device has the most recent firmware installed.
3. Follow the product documentation to reset the wireless device to the factory default settings.
4. Manually set the Primary DNS address to 8.8.8.8 or 8.8.4.4 in the Network Setup of the wireless device.
5. Make sure Dynamic Host Control Protocol (DHCP) is enabled on your router.
6. Turn off MAC filtering or add the IP address of the wireless device in the DHCP table of the router.
7. Temporarily disable encryption for the router; turn it back on after connection.
8. Enable the router to accept network pings.
9. If the router is not broadcasting the SSID, temporarily configure the router to broadcast it; you can turn broadcasting back off after connection.
10. Increase the number of DHCP users.
NOTE: The router may be limiting the number of devices that can be connected.
Thanks. Will post back when I've checked the firmware etc.
Dean
Hi there
Yes, please let me know. I am happy to go through with you on what you dont quite understand. Just reply back and ill see if I can explain better.
Hi, I've updated the firmware (it was old) and have done another full factory reset but I still get the same error messages when trying to connect to the internet.
Thanks
Hi @Baseliner1
Appologies for not replying back sooner (a week?) - are you still having problems? If so, I might pass this onto Sony Support to be honest, as if even the wired connection fails, I think it should be investigated to find out the root cause.
Hi, yes it's still not working. How do I refer it to Sony Support?
Hi there
I can referr this thread to Sony support - but just before I do, when you connected the Ethernet cable did you go into the network settings and run the setup again - in order to choose a 'wired' connection (instead of wireless)?
Hi, yes I did just that.
thanks for your help.
I'd like to add my issue to this. I had some problems when I first bought the player but then a helpful technician suggested the DNS addresses of 8.8.8.8 and 8.8.4.4 which worked for some time. I've just started a Netflix trial and been havgin terrible problems. Some may very well be Netflix's but I have noticed that other streaming serviuces such as Amazon Video also don't work. It's intermittent but then I receive messages to say the connection is down or I should check the settings. Oddly, when I do they show it being connected both physically and to the internet! Ayny thoughts? Are those DNS settings correct? I've also got the player with an assigned static IP which I've further configured with DHCP reservation on my router so there's no conflict on the address.
