Hi, I am still having problems with my DVD/BLUE RAY player. When I power it up it takes a long time, and then sometimes goes to standby. I have reset it to factory settings, and it does the same, the light just flashes. Any advice would be great. Thanks
Hi @Chuckles
Could you also make sure that the device is up to date? Here is the last firmware for your model: https://cutt.ly/Tw1FLg4Q
