I've recently bought a 90-disc set of DVDs each of which contains 4 tracks. And on every single one the bluray player refuses to play the third while playback of 1, 2 and 4 is no problem. All tracks - including the third - play back on my PC with no difficulty, suggesting there is no fault with the discs.
Any ideas about what's going on here would be much appreciated.
Hi @voyeuse
Have you checked that your firmware is up to date? https://www.sony.co.uk/electronics/support/home-video-blu-ray-disc-players-recorders/bdp-s1700/downl...
If it is faulty and still within warranty you should contact the Retailer. Failing that you can contact Sony UK Support
Thanks for the response.
I updated the firmware but the problem persists. As suggested I've contacted Sony UK Support.
No, I'm afraid not. And a factory reset didn't help either.
So since the device is out of warranty, I've switched to a different make of player that has no problem with any of the tracks.
But thanks anyway for the replies.
