Hi all,
My STR-DA5400ES av amp will start and then switches off with "Protect" on the display. I have tried everything suggested - disconnected the speakers etc but nothing works. Has it had it? We have had it from new and it is about 10 years old. It was very expensive and I would have thought it would last longer? My brother has a Denon that is twice as old and it is still going strong!
Any suggestions gratefully received.
Thanks and all the best,
Mike Hammill
I would maybe, if you still wanted to use it, see if there is a local repair shop.
My 10-11 year old old STR-DG720 went like that a few years back.
I'd given it to my son, for his room, as he wanted surround, and it ran great, until "Protect".
I took it to a small tv/audio repair shop, and he replaced a couple of the transistors that are attached to the mainboard, and heatsink.
Only cost about £40 or thereabouts.
It ran for another couple of years until my son retired it and bought a soundbar...idiot! 😁
