Hi, this is my set up:
- KD49XG9005 software up-to-date
- HT-ZF9 software up-to-date
Audio is played from the soundbar and is connected via ARC HDMI
Until recently I have had absolutely no issues with is set up. But recenly I have been experiencing an issue where the volume suddenly and randomly fluctuates. It goes down by a couple of ticks and goes back up. The whole thing just lasts a second max, the sounds goes down and back up like someone has mistakenly hit the volume picking up the remote. It isn't a big problem as it only happens every so often and doesn't last, but it does break immersion whilst watching a movie for example.
Just wondering if anyone else had experienced this and is there a solution?
HI there,
Have you tried a factory reset?
Best wishes,
M
I have the HF-ZF9 and sound is OK, however. I have just posted a message about a 10-12 second delay before picture appears on the TV, after pressing the ON button on the sky remote. I have a scrolling message on the HF-ZF9 which says 'please wait'. Do you experience the same delay?
Hi, did you mean reset on the soundbar or the TV?
Hi, there is a 2-3 second delay max.
Just as an update, I switched off Auto Volume which seems to have done the trick.
