HT-MT500 sound bar stuck in WAIT
profile.country.GB.title
Colesniuc
Explorer
Hello.
I have my HT-MT500 stuck with the message WAIT on the front screen. Does anyone know how can I solve this issue because the Sony staff from chat can’t help in any way. They advise me to take it in service. Thank you
3 REPLIES 3
Anonymous
Not applicable
Hi @Colesniuc, Did you try to factory reset the device?
Colesniuc
Explorer
Hi.
the only reset that I could do is the one with power button and volume down (-)
menu refuses to do anything as well the input
Anonymous
Not applicable
If it's refusing to do the reset and stuck on the wait, then I'm afraid the unit needs to be repaired right now.
From the Sony website you can get a someone to help you from this link: https://locator.sony/en_GB/servicecenters/?link-header
Just make sure to choose the correct filters.
