Does the Hap S1 support any Playlist format I could copy on to the device? I tried several and none seem to do the trick. I got many Playlists and recreating them on the remote or on the device itself is quite tediuos.
Hi there
I have had a bit of a hunt around and cannot find any reference to the ability to playback files from playlists created elsewhere. Only the following files are supported : HERE. Considering that you have tried as well, I would therefore conclude that they are not supported - other than the ones created on the HAP-S1 itself that is.
There is a function called SensMe - see HERE for info.
