I am no longer able to use Spotify connect on my soundbar it worked up till a few weeks ago. I can't remember doing a firmware update but I am currently on software version M34.R.2103. I use an iPhone 7 with the most recent version of Spotify. Any guidance please?
Thanks for the guidance. Downloading music center actually helped me identify the real problem. I was using a different wifi connection for the soundbar than on my device. Once I corrected that music center and Spotify connect started working
Hi there
Try downloading Sony's Music Centre app from iTunes:
https://itunes.apple.com/us/app/sony-music-center-songpal/id724406878?mt=8
Then follow these instructions:
http://vssupport.sony.net/en_ww/help/faq08.html
Further information from:
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/139113
Cool - glad you figured it out
