I have my sony xperia e4 dual. My phone has no displayed contacts only the ICN and myself. I already succesfully imported my sim contacts and no any names or number display in my phone book. Also i try to add a number but still it does not display on my phonebook... pls help...
It sounds like you have some filter settings applied which is hiding your contacts. I suggest that you go to Contacts > Menu button (three dots) > Filter > In this list you can mark or unmark the desired options. If you for example have added your contacts as Local contacts, make sure that you have marked All other contacts under the tab "Local".
Glad to hear! You're welcome.
