How to bypass or destroy android PIN lock?
1. HARD reset = volume UP + power = Vibrate 1x and few sec probably vibrate 3x and this still loop .. no recovery
2. Connect USB = Volume down + USB = fastboot devices = no devices :'(
There are these options:
1. See this thread:
/t5/FAQ/How-to-unlock-a-phone-w-o-reseting-reformating-the-phone/m-p/927295#U927295
2. You have to perform a software repair using PC Companion.
1. See this thread:
1. The phone has disabled Wi-Fi or data and its not connected with MyXperia
2.WORKS THANKS SO MUCH 😘
You are welcome.
