according to xperia support, there is an option to choose between mtp and msc. i sent them this screenshot two days ago, no reply, of course.
I'm very sorry to hear that you were not able to get this information from your local support.
I'm afraid MSC-mode is not supported by Xperia E4 on the latest firmware. Also on later models like Z3+, M4 Aqua and Z5 you need to use MTP to transfer data over USB.
You can try to enable usb debugging mode in developer options first.
To enable dev options, go to settings-about phone,tap several times on build number.
with usb debugging mode on still has only mtp mode + windows can see xperia as a composit device
i guess a factory reset or "repair" via pc companion perhaps could do something. or could not.
the phone is less than a week old, so i won't do any of these.
i bought a sony device because i've fed up with chinese noname brands' support and their "do a factory reset" solutions
waste of time. I did the repair, nothing has changed.
it could be even worse
before repair of course i did a backup and now this little pc companion can't restore it... in fact it doesn't do anything, the progress bar hangs at ~75%
Ive got same problem, cant switch between mtp and msc because there is no option to do that in usb connectivity. Tried all solutions i could find out there but nothing helped. I see theres quite a bunch of people with same problem, wouldnt it be the time already for you to fix this, Sony?
My computer running XP does not recognise my Xperia E4g when connected via USB cable. I have connected to other computers running Windows 7 and 8 and there is no problem. I have also tried different USD cables.
Is Android version 4.4.4 compatible with XP (32 bit)?
Thanks for any help forthcoming.
