according to xperia support, there is an option to choose between mtp and msc. i sent them this screenshot two days ago, no reply, of course.
On the Z5C, I installed and removed an SD card and soon after reconnecting the usb cable, there I was able to use the sony drive as a mass storage disk. This is using a window pc.
Yea as jani1 said they don't know what are they selling....
couple weeks ago i asked them (UK online support) why my phones system uses 1.1 GB RAM... and they answered me to move my data to SD card. this was only solution of problem in their mind...
It was so embarasing....
MSC mode is also important to be able to use the internal SD card as an external device. I need to be able to backup my 128GB SD card to my mac, but if MSC mode doesnt work, the backup program wont recognise it as an external device and therefore will not start the backup. I dont want to keep taking out my SD card and suffer my sim coming out and the phone switching off each time (Xperia Z5 Premium)
This is something I will consider more when buying a future phone, I wished my next would also be a Sony, but it doesnt seem to be looking good unless "little" obvious things like this are sorted.
That app won't open on a Z5 with 6.0.1. It just crashes immediately.
