hi,
I am trying to import media from memory cards taken from an HX20V and RX100
I can see and select the media to import but when I browse to import to a folder the OK button is greyed out.
If I select "import by date" this works fine but I cannot import to a folder.
See attached jpeg showing the greyed out screen.
Hello Scotview
Have you checked to see if you have the latest version of Playmemories Home installed from the following link:
http://www.sony.co.uk/support/en/product/DSC-HX20V/updates
Thanks,
Simon
Hi blaireau,
Thanks for the link, I updated PlayMemories Home as requested, nice calendar feature.
The folders are still Greyed out.
The C/Dell folder is not greyed out, see attached jpeg. The C/Video folder is also not greyed out.
The C/Users folder is greyed out and this is the obvious place where I would wish to import the selected photo and video files from the camera's card.
Could it be that PMH doesnt like folder structures with several levels, this was a problem with some programmes many years ago.
I will continue to upload all video and photos from a card then delete via Playmemories Home but it is a shame that I cannot use the preview and selective upload feature to save my hard drive getting full.
Do you think this is a bug ?
Best regards
Scotview.
Hello again
This does sound like it could be some kind of bug. I see that you are using Windows 7 so if you let me know exactly which version you are using (32 or 64 bit, Home/Professional etc.) I will refer your issue to Customer Support to see if they have any ideas what could be causing the greyed out button.
Thanks,
Simon
Hi Blaireau,
Thanks for the reply.
I am running Windows 7 Home Premium.
64 Bit Operating System.
It will be interesting to hear what Customer Support say.
Best Regards
Hello again
Thanks for letting me know. I will escalate this to customer support and I will be in touch when I hear back from them.
Simon
Message was edited by: blaireau_photo
I'm using latest version of PlayMemories, Windows 7 64 bit. And I can't choose folder now I moved my photos under a Onedrive-folder. I can import "outside" onedrive-folder...
Still a bug???
I'm having the same problem too. It won't let me select a DropBox folder to import my photos into the 'OK' button gets greyed out. Any ideas?
Also having the same problem – are there any fixes?
I am appalled at just how terrible a program PlayMemories is – expect a lot better from Sony what a waste of time.
What happens when you click the Album 2012 folder?
I guess the software wants to add a date folder and doesn't allow to add a subfolder to a date folder. (= wild guess)
