Ahoj
Poradí někdo kde koupit (sehnat ) sluneční clonu Sony alc sh107 pro sal 40700g
Dík Petr
According to Google Translate, you're looking for the sun visor/lens hood ALC-SH107 for the Pro SAL 40700G lens, but I couldn't find anything related to this lens at all. And the support page for the visor mentions it not being available in the UK.
Have you tried reaching out to your local country support?
Hope this helps!
- JD
Ano to jsem zkoušel, ale žádná odezva. Dík za zprávu
Could you tell us your country and more info about the lens or the support page for it?
Preferably in English since this is the English community and so others can help without resorting to Google Translate ^^
I'd say that https://www.sony.cz/ would be the place to go.
darkframe
Ahoj To jsem zkoušel hned na začátku a žádná odezva. Dík
