i will tell you the bugs in the software and we need un update very soon !!
1- in battery consumption phone radio is killing the battery more than 40% always although im using 1sim or 2 sim with very good network coverage ..this bug is with mos xperia c users
2- Battery when reaches 30% it drains very fast till 13% ..all xperia c users face this proplems
3-only 1 gb from the 4gb internal memory can install apps on it ..come on ! i had a low ranged lg phone with also 4gb and we can install apps on 2.5 gb from the 4 gb ..now with a midranged sony we cant and there is another 1.2 gb unused so why ?
4- when you drag notification bar with 2 fingers it shows another notification panel ..it has a tab of your information (your name ..number and pic )) when you change your picture it doesnt appear its always blank ..
we need an update to fix the bugs we are not demanding kitkat just make our phone not useless !
same problems is been faced by me. Sony have to do some bug fixing for this, otherwise its a total waste for money.
Can anyone please help.
I cannot see the usb connectivity just after i turned mu usb debugging mode on.
Now even after i have turned it off , still , when i connect throgh cable , it doesn't shows USB connections.
There should be settings-xperia connectivity-usb connectivity.
Hi dear friends
I purchased Sony C with lot of hopes but frustrated with the product many problems its have
1. Radio F M clarity is not good, regarding this given to service they not respond properly
2. its take to charge the battery minimum of 4 hours
3. Music output is not upto the mark
4, When ever i give to service they give back with new problem
really fedup with the sony xperia-C its a dead investment.
purchased with lot of expectation
service people not at all respond properly, its a just one month mobile given to service till now 5 times
but still problem not resolved,,
