i will tell you the bugs in the software and we need un update very soon !!
1- in battery consumption phone radio is killing the battery more than 40% always although im using 1sim or 2 sim with very good network coverage ..this bug is with mos xperia c users
2- Battery when reaches 30% it drains very fast till 13% ..all xperia c users face this proplems
3-only 1 gb from the 4gb internal memory can install apps on it ..come on ! i had a low ranged lg phone with also 4gb and we can install apps on 2.5 gb from the 4 gb ..now with a midranged sony we cant and there is another 1.2 gb unused so why ?
4- when you drag notification bar with 2 fingers it shows another notification panel ..it has a tab of your information (your name ..number and pic )) when you change your picture it doesnt appear its always blank ..
we need an update to fix the bugs we are not demanding kitkat just make our phone not useless !
Hello over there,
I have Xperia C and I don't have any bugs specially with new Rom posted by Xda team:smileylove:, the only one is the front camera, but i think if you get a good light on front it will solve the issue, notably is good for slow network video chat
Best wishes,
i have a Problem on My Sony Xperia C. cant connect to mobile internet, even i have a prepaid load and a correct APN. and also my GLOBE sim card cant detect on my sim card slot 1. i cant believe this! my phone is also 3 months on my hand,.. i've go to sony service center but they cant resolve the issue.. they said they're offline and no hardware parts.. etc... please help SONY what should i do.....!?
