x
sd card problem on xperia c3
SOLVED
user123
Visitor
Hi, i am facing sd card problem, where it gets disconnected again and again. The sd card cover also seems to be loose and it comes out with the card. Iam using sandisk 32gb micro sd card. Any idea how can i fix this?
thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Thommo
Genius
When you place the SD card in the phone do you push it in untill you hear a locking click - Like for example a pen in that you hear a click letting you know it's locked in and then you would push it a little bit again to unlock it and release the SD card
2 REPLIES 2
Thommo
Genius
user123
Visitor
I have tried multiple times but sd card lock click never happens. Card lock doesn't seem to work.
