- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
November 2014
November 2014
Hi, i am facing sd card problem, where it gets disconnected again and again. The sd card cover also seems to be loose and it comes out with the card. Iam using sandisk 32gb micro sd card. Any idea how can i fix this?
thanks
thanks
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2014
November 2014
When you place the SD card in the phone do you push it in untill you hear a locking click - Like for example a pen in that you hear a click letting you know it's locked in and then you would push it a little bit again to unlock it and release the SD card
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2014
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2014
November 2014
I have tried multiple times but sd card lock click never happens. Card lock doesn't seem to work.
