HI
In the manual there are many differents resolution to choose for the camera. In my application i only can select between the format 16/9 or 4/3...Is there a trick to select format and the resolution?
Thanks in advance.
François
Hi @francoistoen,
You need to change the camera mode to manual in order to be able to change the resolution for the camera.
Press the icon with the yellow camera on it and you will get different camera modes to choose from. If you choose Manual you will then be able to change the resolution in the camera settings.
Hi @francoistoen,
Thank you for your fast answer. I will test it now.....
François
I tried your solution and eveything is OK....Thanks again:smileyhappy:
You're welcome!
