I bought two Xperia C devices, with the original firmware there was no "Portable Wi-Fi Hotspot Settings" under "Tethering & Portable Hotspots" menu. I updated one of them to the last firmware 16.0.B.2.6 but still there's no "Portable Wi-Fi Hotspot Settings".
As you know if you dont access to the Wi-Fi hotsport setting you cannot change the define the Wi-Fi key and the wi-fi hotspot is totally unworkable.
Meanwhile the wi-fi hotspot is working well, when the data is on, you can turn it on and it's also been found by other devices like laptops or mobiles but as you dont have a wi-fi key you cannot use it.
By pressing in the following area:
You should end up in the following menu:
But if you don't, I suggest that you send your phone to a service center so a technician can examine your unit. If the phone is not launched in your country, you will need to contact your retailer or send it to a service center from the country where you purchased your unit.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
To access the menu where you can configure your Wi-Fi hotspot, you need to tap at "Portable Wi-Fi hotspot" and you will access a new menu where you can change password and network SSID.
Check the following link and you can find some info about using your device as a protable Wi-Fi hotspot:
http://userguide.sonymobile.com/referrer.php?region=global-en&product=xperia-c#Connecting-to-wireles...
It's been solved, thanks for you attention and proper reply!
That's nice to hear, anytime! :smileysmileythumbsup:
