I purchased my new Xperia c and unboxed it. I inserted new sim card and made my first call. The ear speaker is not working !
please help me
Thank you . . . a lot You saved my heart. i just uninstalled the updates of the same and re installed. . .now it started working. Love you
Settings-apps-all-smart connect,clear data.Check again.
That sounds good.
I am sorry,you should stop by a sony service.
Lot of Thanks
