I got problem while updating Android 4.2.2 16.0.B.2.13 firmware using PC Companion and then my phone is not working.Now it just show the sony text on screen and it doesn't turn off or turn on
:'( .please someone help what to do now??
Use sony update service to update/repair:
http://www.sonymobile.com/gb/tools/update-service/
i have this same probelm.. but my desktop does not read my phone.. any suggestions?? pls help
Force shutdown the phone(press the little button on the back).After that try to repair with SUS.Do not turn on the phone.
I also have this problem while trying to update to latest firmware. The phone only display the text sony. It happen when the usb was disconnected while the firmware is being dowloaded from the PC to the phone. Now the phone is not responding at all. How to fix it?
Force shutdown the phone.Turn it on normally after.
how to shut down forcely
I am also facing the same issue. and problem is that PC companion is also not recognizing it when i connect it. For using Updte service also it says first switch off the phone but all options are of reste not of switch off.
So how to do that?
I am totaly stuck.
Just charge it for 2 hours and force shutdown as in my upper post.After that,SUS should see the phone.
