- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello, all.
My TV will speak the results of whatever I’m searching for, despite Talkback and Screenreader being turned off. I don’t think it’s Google Assistant causing the issue, either.
Can anyone help, please?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi nisudji, I don't believe that there's a setting on the TV for that, I'd contact Google for further assistance on this one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @nisudji Have you tried a soft reboot? Hold down the remote power button until you see Restart on the screen.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Do you mean the "showing results for ........."
It says after searching on play store ?
I can't find a way to turn it off either on my x95k.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yup, that’s exactly it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the response..
Yes, I’ve tried all of that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey nisudji, if it's saying "showing the results for" that's normal, it functions pretty much like the usual Google Assistant, if this is not what's happening, please elaborate more.
Also, check the software version and post it here. Press Help on the remote control, you should find it on the upper part of the screen.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, Hannah.
Yes, that’s what’s happening, but I’d like it to stop.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, Hannah.
Okie dokie,
Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey nisudji,
It was my pleasure! Let me know what they say.
