Hello, all.
My TV will speak the results of whatever I’m searching for, despite Talkback and Screenreader being turned off. I don’t think it’s Google Assistant causing the issue, either.
Can anyone help, please?
Hi nisudji, I don't believe that there's a setting on the TV for that, I'd contact Google for further assistance on this one.
Hi @nisudji Have you tried a soft reboot? Hold down the remote power button until you see Restart on the screen.
Do you mean the "showing results for ........."
It says after searching on play store ?
I can't find a way to turn it off either on my x95k.
Yup, that’s exactly it.
Thanks for the response..
Yes, I’ve tried all of that.
Hey nisudji, if it's saying "showing the results for" that's normal, it functions pretty much like the usual Google Assistant, if this is not what's happening, please elaborate more.
Also, check the software version and post it here. Press Help on the remote control, you should find it on the upper part of the screen.
Hi, Hannah.
Yes, that’s what’s happening, but I’d like it to stop.
Hi, Hannah.
Okie dokie,
Thanks for your help.
Hey nisudji,
It was my pleasure! Let me know what they say.
