Hi All, Just had an update to PKG6.5076.0635 does anyone knows what bugs it fixes?
Hi Lemax20, it resolves an issue where there was no picture and/or sound when switching to Terrestrial input.
Have a look at the support pages https://www.sony.co.uk/electronics/support/lcd-tvs-android-xh80xx_x80xxh_x81xh-series/kd-55xh8096/so...
It has a security update from Jul 21. Installed over USB which was a palava as it needed to be on a 4Gb USB drive via Windows (macOS extracts the ZIP file).
Thanks!
Do you have a certain issue that you're after a resolution for?
