Hi. I have an irritation with my TV if left on YouTube and then put into standby. When I turn the TV back on I cannot get the youview app to work. I have to do a full power reset which eventually sorts this out. I'm not sure if a software update has caused this as it never used to do this when I bought it in 2018. Any help appreciated. Thanks.
Have you got any other devices connected to your TV?
If so, as a test, disconnect them and see if you still have the issue.
A recent posting has fingered CEC (BraviaSync) on a connected device that was supposed to have CEC disabled, but it wasn’t, as causing a very similar issue.
Hi Mikeyb1803, what's the software version of your TV?
Hi. Thanks for asking version is 9
IDK, this is not the software version.. Usually it's on the Help Menu not the settings..
