Hi
I have standard remote, model RMF-TX200E.
From some time - I don't know exactly when, battery life went to 20-25 days when using normal betteries, 14-18 with rechargable ones.
I upgraded quite late to the last Android version (remembering various issues with 6.0), possibly in December and not long after that I think I started experiencing problems.
Remote has SW version 5.3.14.018
TV has 3.925
I tried re-paring the remote, activating and deactivating voice controls - nothing seems to help.
Some ideas maybe what can be done?
thanks
Chris
Hi Chrisc383,
Can you check that your firmware version is indeed up todate?
Thanks,
Sean Mc
Yes, TV firmware is surely the latest. As for the remote - I clicked on the update in TV settings, then I was told it's the latest version.
