I cannot view Google cast photos/videos sent from my phone to my TV using the wired LAN network setting.
However, if I remove the ethernet cable from the back of the TV and change the network setting to Wi-Fi.then it works fine and I can cast successfully. I use the wired LAN as a matter of course so would prefer not to have to disconnect the ethernet cable and change the network settings every time I want to cast from my phone.
I'd be grateful if anyone has any advice/ideas that might help me?
Hi micking80,
Please find more details on connecting to a network using a LAN cable here.
Hope this helps!
Thanks,
Sean Mc
As suggested in my question, I have a working cable LAN network, so sorry but generic advice on how to set one up is not helpful to me.
I think the problem is your network router, that blocks the connection between wlan and lan.
Buy a new network router.
