HI, CAN SOMEONE PLEASE ADVISE HOW I CAN GET RID OF THE TINNY SOUND FROM THE TV SPEAKERS. 49XD8088. MANY THANKS
Settings > Sound > System sounds
Turns your audio system on, and allows you to control it.
Inside this category: On, Off
Manolo
I DONT WANT TO TURN THE SPEAKER ON OR OFF, I WANT TO KNOW WHEN THEY ARE ON HOW TO REDUCE THE TINNY SOUND. THANKS
... for speakers ON/OFF is:
Settings > Sound > Headphone speaker link
Switches the TV's speaker on/off when headphones are connected.
Inside this category: Off, On
Have you try?
Manolo
Your welcome...
Manolo
