Since the November Android update my KD-49X8309C has been suffering from stuttering with the Sports and Animation modes when prior to this update there was any. Basically when set to smooth it isn't as smooth as before and seems to suffer frame rate issues in games etc. I prefer to use the sports and animation modes for gaming as I prefer the smoother refresh rates.
Has anyone else seen issues since the latest update? I wish I could uninstall the update as it seems to have made things worse.
you can't uninstall the update but you can try a custom reset... Somtimes it work on fix problem like this (especially after un upgrade).
Manolo
