- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony XE90 Dolby 5.1 Pass-through
Hi
Can anyone confirm if the XE90 range, specifically the KD-49XDE9005 does Dolby 5.1 passthrough out of the digital optical output, I need it to play nicely with my Sonos Playbase and this is a requirement
Thanks in advance
Steve
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, it does Dolby Digital and DTS. I use pass through on a number of devices including Sony PS4 Pro and Youview PVR.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
DTS passthrough does not work from most 3rd party apps as the MediaTek driver lacks support for ENCODING_DTS and ENCODING_IEC61937 Android AudioTrack APIs.
Some apps still use the old PCM hack which might or might not work. Problem with it is that it uses the umcrompressed PCM pipeline to output compressed bitstream audio. As soon as anything alters audio in any way (volume change, audio mixing), the compressed bitstream gets garbled which might harm your audio hardware or your ears as only a high pitched noise is output then. NOT RECOMMENDED!
Passthrough will work properly from external HDMI devices though, also for DTS.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
Thanks for the responses, I'm just really concerned with Dolby Digital 5.1 form the digital optical output, as I don't think the Sonos handles DTS - so on that basis, is Dolby Digital 5.1 pass through ok?
Steve
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Dolby should be fine for all sources. It can only be a problem if the app in use only supports the ENCODING_IEC61937 API. All apps that I know make use of the ENCODING_AC3 API though.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Does anyone have an update on when we might see this implemented?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@jaketame wrote:Does anyone have an update on when we might see this implemented?
In which respect, when I am using external sources, PS4, Youview, PS3, DVD etc they all pass thgrough Dolby Digital 5.1. All the apps I use, native video player, Prime video etc also output DD5.1? (the only Apps I don't get 5.1 on are Youtube and Google Movies)
What are you stuggling with exactly?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@stormyuk schrieb:the only Apps I don't get 5.1 on are Youtube and Google Movies
YouTube only support Opus, Vorbis and AAC audio. So not 5.1 via passthrough unless the app can transcode stuff to Dolby.
Google Play Movies works for me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I noticed I still cannot get 5.1 sound from Google Play Movies, is this because I am using Optical and not the HDMI connection? Does Google Play Movies support 5.1 Dolby Digital via Optical (Both Netflix and Amazon seem to work fine for me, as does the internal video app).
Thanks,
