Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Hi.I having problems updateing my Sony kdl-43w807c.Updating crash on 88% and having error2123???Please help.Thanks.
Hi @Stasym
I have sent you some instructions via private message. Please let me know how you get on.
Work it!!!Thanks a lot for you help Quinni.
You're welcome
Hello, is this solution works on other type of sony android tv's? Like kd-65x8505c that I have here?
Hello
Yes it does. I have sent you a private message with the instructions.
Hi my friend! I have the same problem with my sony kdl 50w756c. It stops updating at 99%.
Can you please sent me too, the instructions to solve it. I am in Greece
Ok it fixed. Thanks!
Hay, friend, you're kind of helping everyone here) I have a sony kdl 26ex320. An error 2123 occurs when you try to update the software and after authentication. Please help me. I'm desperate, I've tried all the ways.
Have you got this patch?
https://www.sony.co.uk/electronics/support/lcd-tvs-legacy-lcd-tv/kdl-26ex320/downloads/Z0000288
If so, and it’s not that, you could try looking in the forum here under Other TVs (yours is an Other TV, as it predates the Android sets this section is about, and is too small a screen to be one anyway, as they start at 43ins).
And a Google search for ‘Sony 2123 error code’ turns up quite a few things you could usefully look at as well.
