Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Hi. I'v solved this. 1)install a new firmware via usb. https://www.sony.ru/electronics/support. 2)reset TV to factory settings about 3 times. And all is working.
Why does it need to be done 3 times ? Are Sony TVs a bit slow to take instructions ?
Hi there,
Could you please help me too? I have the same problem as the others above with 48w600b
and the error code is 4057
Thanks.
Hey there,
If you still have the solution could you possibly send it to me aswell, thanks!
Hi
I have the same problem as they did back in 2016 is it possible to get the instructions for upgrade?
Thank you
My thread:
https://community.sony.si/t5/android-tv/sony-kd-55x8509c/m-p/3848049
Regards
Help me pleade
Sony KDL-50W755C. error 2123
