Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
it works!! Thank you
Hi I'm having the same problem. Model KD43X8305CBU
Please help!
I have a similar problem.
Someone pressed a button, and now there is a network plug on the screen with a red cross.
Television responds to nothing.
There is a key combination to get the television out the update modes...?
Hi @lestolk
The TV is probably updating to the newly released FW. See:
Suggest leaving it on for a while for it to update.
YES !
it's working again
THANX
Hi Quinnicus
Im having the same error message and am unable to update FW on my W755. Any chance you could assist?
Thanks
Hi, I'm having the same issue it stops at 76% exactly in the download from wifi or lan and the usb copying just shutsdown the tv i've tried to reset and everything im desperate my tv just broke down after 5 months so sony came and gave me a new one but now i cant update !
Please help!
Thanks in advanced
-Thomas
My Tv is a 75x8505c
Hi there
Ive sent you a PM with some instructions, let me know how you get on.
