Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Hey @Anonymous, would you mind sending me some help since I can't get it to connect succesfully? I have a sony 32W605D.
@Estbarul wrote:Hey @Anonymous, would you mind sending me some help since I can't get it to connect succesfully? I have a sony 32W605D.
Hi @Estbarul, can you post again under Other TVs?
That's not an Android set you have, so you won't have the same issue as those earlier in this thread, and your query will do better in a thread on its own.
Ok I see thank you very much! I used a public DNS and it worked now, thanks anyway!
@Estbarul - Cool, glad you have managed to get it working.
The fix I have wouldnt have worked with your model TV anyhow.
Thank you, yeah I'm still going to return it since it doesn't work for the application I needed. ty.
Hi
I have found this site/post as I have the same issue
I have the 65XD9305
Could you please PM me the fix too?
Many thanks
Hi @lorri1903
I have sent you a private message with some instructions - let me know how you get on.
Thank you SO much @Anonymous The fix worked perfectly!
Brilliant - You're Welcome
I have just bought a KD43X8305CBU-ES and am having the same problem over wifi and LAN connection may I have the fix please?
