Hello, I have a problem with the SONY Bravia XH90 TV with Android. I'm trying to find English channels through a home analog antenna. The antenna works on the older LG model without Android and gets all channels, unfortunately on the new Sony with Android it does not find any channel.
Is the antenna input damaged on the TV or I have to set something in the settings ??
Thank you for your help.
Are you trying to tune/scan for analogue channels or digital ones?
