Brand new TV. Updates all loaded. Tuned in. No BBC text or red button service! I know its still there as on old Sony TV. Please tell me what I need to do. Thanks.
Try removing the aerial cable from the TV, perform Digital Auto Tuning (no channels will be found obviously but that's ok), then reconnect aerial and tune again.
Win_88
removing the aerial didn't work please can you suggest something else. thanks
Hi simonis2310, assuming it's the same TV (Correct me if I'm wrong),check the following link:
https://www.sony.co.uk/electronics/support/articles/00257438
Hi Hannah
sorry my tv is ag9 55 inch model. I did try removing the aerial etc but that did not work. my other older models still have the bbc text service
