Hdr will not work on my ps5 with the 4K Bravia 2015. I have it it connected to hdmi 2 and have it on enhanced picture setting but the ps5 is still saying it’s not supported
Just checked the make and unfortunately the T.V doesn't support HDR.
Maybe the TV supports 4K but doesn't support HDR, what model TV do you have?
@Gboyle122 I've also reached the same conclusion as David, you can check the spec sheet for yourself as well. Sadly, support for HDR is not listed.
