Hi all
I have a Sony Bravia 4 k tv that cost a lot of money and is just out of warranty surprising ?
Once i turn it on - the Light flashes 6 times - then turns off - no picture. - tried unplugging , holding the buttons in but did not work . Can you tell me how much to fix this issue please and what is the issue ?
The Tv details are as follows Sony Bravia tv - 55 inch 4k KD 55X8509C S/N 6811309 P/N 18706601
Any help would be great
regards
John
Hi @jjleonard
I’m sorry but this is a community of customers so your best course of action is to contact Sony Customer Support for your Country or Region. As it is out of warranty then your options are limited. The chances are the power board is faulty and may cost more to repair than to buy a new modern TV. However only Sony will be able to tell you.
Hi all
Once i turn it on - the Light flashes 6 times - then turns off - no picture. - tried unplugging , holding the buttons in but did not work . Can you tell me what is the issue ?
You are supposed to post something different this time, and something that shows you have taken on board the reply from @LightFoot and not just completely ignored it 😢
Hi jjleonard, make sure that you try the force reset specifically as described here and that you get the green light: https://www.sony.co.uk/electronics/support/articles/00159906
Usually 6 times red means the screen is faulty. I don't think this is repairable. Where are you based anyway?
