Android TV/Sony Bravia TVs have a “screen saver” with a picture roll of real scenes.
Is there a way to find out the locations of these pictures?
They are on google servers
Okay, thanks.
How do I access them? I want to know the locations of the pictures
I don't know of a way to access them. I tried looking it up but found nothing. Everyone just shows you how to change the screensaver for some reason
You may be able to have a look at what is on display on the tv via Google Home app on a smartphone. I didn't try since a long time but that should be the way
I used my Android phone, tap on google hone with the camera icon next to the search bar, take a photo of the TV screen then search, that may find something if you are lucky.
