my KDL-32WD754 has lost it's sound.
The screen has a strange message:
Short Press: PROG/INPUT/VOL
Long Press: Power Off
Tried to understand and follow the above instructions without joy.
No sound.
It seems to me like a button on the TV set (not the remote) is stuck ....
That does seem right but ...
1. I have pressed al buttons and cleaned remote.
2. I don't have another remote to swap out and test independently.
3. I notice that the light under the screen is flashing whether red or amber. This is as if a button on the remote is being pressed and continues even if I take the batteries out of the remote.
A further problem is that I am not able to access the Settings menu ... should the solution lie therein ...
Oh, just re-read your note. Good thought. Button on the TV.
I don't think this model KDL-32WD754 has buttons on TV. I have never found them. I shall go and find the manual and see if they are hidden somewhere cleverly.
S O L V E D ! ! !.
Well done rooobb. The KDL-32WD754 does have buttons hidden on the back.
I had a 1 Tb hard drive stuck to back of telly for USB recordings. It had gently come unstuck and pressed down on the buttons. Well I never!
Sorted!
Cheers rooobb.
Award yourself a cold bottle of your favourite nectar, straight out of the fridge.
Neil
I am happy for you I guessed right
Unfortunately you are too far to get my prize cheers
