Hi all
I have a Sony Bravia 4 k tv that cost a lot of money and is just out of warranty surprising ?
Once i turn it on - the Light flashes 6 times - then turns off - no picture. - tried unplugging , holding the buttons in but did not work . Can you tell me what is the issue ?
The Tv details are as follows Sony Bravia tv - 55 inch 4k
KD 55X8509C
S/N 6811309
P/N 18706601
Any help would be great
Only a technician can diagnose the fault, but probably the 6 flash code means the panel has gone on your 6 years old tv.
This guy @jjleonard has asked in a previous thread, been answered and just repeated his question there, and now here for a third time.
He seems to be in write-only mode 😢
@royabrown2 you are right! BTW I'm also amused to see how smart are the tv that can recognize if an extended warranty is in place or not and get faulty accordingly after 1, 2 or 5 years...
