When the power is switched on my Sony Bravia restarts over and over.
Turning the power on at the wall (remote and maunal control have no effect) the Sony logo flashes up for around 4 seconds then dispears then the white LED apears for around three second fades and then the process starts again, and again. It only stops if the power is turned off at wall.
No red blinking lights.
Hi @Mumsandtv
or
https://sony-paa-pa-en-web--paa.custhelp.com/app/answers/detail/a_id/129220
1. Uninstall all the apps that you have installed (Kodi etc.)
2. Clear cache for all Apps.(Settings - Storage & reset - Storage - Cached data - Clear cached data - OK)
3. Perform the usual procedure for Factory reset your TV. (Settings - Storage & reset - Factory data reset)
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/66442/kw/factory%20data%20reset
